Home > Technical > Urgent help please
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Urgent help please
So tonight I pulled the car off drive to turn it around so I could wash it. All good until I tried to start it after I washed it. Loads of clicking, warning lights everywhere with bongs and says battery low. I have tried jump starting but no joy. I can’t imagine anything getting wet anywhere in the electrics as I’ve washed the car loads of times with no issues. Has the battery given up the ghost or something more sinister. Got it plugged into the CTEC charger now and crossing my fingers. Need to move car as I can’t get the van off the drive as it’s in the way. Any advice would be great
Post #635605 Wed Sep 06 2023 7:02pm
I'd guess a battery on its last legs unless you know it's a recent good one. Hopefully the CTEK can get enough in to it to allow an engine start. At the minimum, expect to need a new battery. But rather needs the voltages checking to see if it might be a tired alternator. 2012 SDV6 - it's missing a couple of cylinders
Post #635613 Wed Sep 06 2023 9:08pm
Johnrrs
Thanks for your reply. The battery is the original one and the car is 2015 year. Started perfect when I moved the car but now nothing. The CTEC is on 3 lights and I have it on AGM and recondition mode so fingers crossed that I can get it started. Unfortunately it has been on the 3 lights for around 3 hours now. I’ll leave it all night and see what happens. Will the recovery company be able to get it started if the battery is kaput?
Post #635616 Wed Sep 06 2023 9:15pm
Johnrrs
If this is a battery problem will it be the main starter battery that’s at fault or could it be the smaller leisure battery thing that assists with stop start etc?
Post #635619 Wed Sep 06 2023 9:37pm
I think AA sell batteries. So that maybe an option
Post #635620 Wed Sep 06 2023 9:43pm
Johnrrs
I’m with green flag so if they can sell me one that would be great. Gunna get up at 6 to see if the car starts then call them if not……..
Post #635621 Wed Sep 06 2023 9:49pm
Johnrrs
So I got up this morning and the CTEC charger had 4 lights on. According to the instructions when it gets to 4 lights the car should start. Pressed the start button and hey presto she fired up. The ca is now in my garage and on charge. New battery required now me thinks. Any recommendations? Does the new battery need coding to the car? I’m pretty confident I can do this job myself but not the coding bit as I have nothing to code it with. To say I’m relieved is an understatement even though I’m probably going to work today just to pay for the new battery. Thanks for all the replies.👍
Post #635626 Thu Sep 07 2023 6:15am
TheWojtek
No, you just remove the old, put in the new, program the radio stations again. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635627 Thu Sep 07 2023 8:16am
Brian Considine
Seven years out of a battery is pretty good going & these cars need a good battery. It owes you nothing so replace it.
Mine was getting a bit tired so, with winter looming time for a new one so started shopping around.
Car does not have stop/start (thank goodness) but I decided on a Yuasa & shopped around, tried the usual suspects like KwikFart, Formula Once, National Tyres, a few independants and the local motor factors - prices for the same battery all over the place like a cheap suit.
Then, for a laugh really, I tried Halfrauds Mobile "on the drive" - best price by far, turned up on time, job done. 2006 RRS 2.7 HSE.
Post #635630 Thu Sep 07 2023 11:06am
Disco_Mikey
This is incorrect. The BMS should be reset, as it does affect the smart charge system, and subsequently charge rates etc
If you don't reset it, you will likely not notice any issues, but there is a lot that goes on in the background with these cars Thumbs Up
Post #635631 Thu Sep 07 2023 11:35am
Johnrrs
I’ve had the CTEC charger plugged in all day now and all the lights or on including the green battery ok light. I thought these chargers go through a sequence and check if the battery is faulty and if so doesn’t pass the 5th light test and goes red. Does this mean my battery is ok?
Post #635642 Thu Sep 07 2023 3:28pm
TheWojtek
Disco_Mikey wrote:
This is incorrect. The BMS should be reset, as it does affect the smart charge system, and subsequently charge rates etc.
I assume this does not have to happen whenever the battery is removed, but the BMS measures the actual capacity of the battery and adjusts voltage and current accordingly? So in case of a vast difference between old and new it will not charge above a predetected limit of the old? Like "it only counts down"? That's a poor management system in my book if it measures the capacity but ignores an increase.
It's the "Battery Replacement" procedure in IID and SDD, right?
OK, thanks for this tip, I was oblivious to this and changed a couple of batteries within past 15 years, what exactly could've go wrong? Regards etc.,
Wojtek
Post #635644 Thu Sep 07 2023 3:42pm
NoExpert
The BMS accounts for battery wear over time. Not resetting it will make it think it’s still charging an old dying battery rather than a new one at full capacity. So you get less charge and less battery life.
Only applies to 2010+ Land Rovers, but you’re in luck, not the 3.6 TDV8. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635645 Thu Sep 07 2023 4:28pm
Johnrrs
Ok so been having a play with the car tonight and even though the CTEC charger says all is fine and dandy it obviously isn’t. When I unlock the car and open the door there is a big warning on the dash saying battery low please start engine. The car will actually start and all warning lights go off. I can’t risk going out in it unless it’s to get the battery checked and replaced if required. I may even get a company like AA or Halfords out to replace the battery as the prices seem ok(around £300 fitted)l I’ll keep the forum updated with what I do.👍
Post #635647 Thu Sep 07 2023 7:03pm
It maybe because you connected the charger directly to the battery, rather than the neg lead to chassis.
Computer thinks it’s low.
Just fit the battery yourself.
Or maybe the battery is ok if the car has had little use and that is what the ctek is for
Post #635657 Fri Sep 08 2023 7:49am
