![]() | Home > Faults & Fixes > Abs traction and suspension lowering fault 2008 rrs |
All for tires match, similar wear and the correct air pressure? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Hullrrs Member Since: 29 Aug 2023 Location: Hull Yorkshire Posts: 33 ![]() ![]() ![]() |
Hi thanks for your reply
Definitely check the tire pressures. After that you’ll want diagnostics to help pinpoint the issue. Hopefully not water getting into the TCCM. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
First thing I checked was the tyre pressures and all good there
Transfer Case Control Module. On a RHD I believe it is on the right side (looking at the engine) behind the battery. Sometimes water can drip down onto it and it’s not the best sealed unit I’ve seen. Pull the connector and check for corrosion on the pins.
Thank you for your replies
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1876 ![]() ![]() |
11.8 volts is not good
Thanks
These beasts are voltage sensitive and cause all sorts of errors to be thown up. |
11.8V is bordering on a flat battery,, and 13.9V running is not right. You should be seeing 14.6V at idle and a fully charged battery would be at least 12.6V. I would be investigating your alternator,, if you have access to a clamp meter you can check the charging current. 2010 RRS, TDV8
Exactly what gogsy1956 said and exactly what mine has shown for almost two years now. May need an alternator and battery cause those numbers aren’t good at all.
Thanks everyone
It’s not too terrible of a job. Just a little fiddly to get access. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Right then
