Home > Faults & Fixes > Abs traction and suspension lowering fault 2008 rrs
NoExpert
Definitely sounds like the alternator isn’t doing its job. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635534 Sun Sep 03 2023 2:50pm
Hullrrs
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Right quick update on this
Took car to LR local to me told them about the issue
They kept the car for a day and checked battery and alternator
Technician said battery was 90-95% alternator was working fine
He said he’s seen lots like this and it could be because it’s used mainly for short trips so battery is never fully charging.
Strange thing is it’s never done it since the code was originally cleared by first garage
The guy I got it from did say it had been sat not used for 4-5 weeks before I got it so maybe the battery was low and stored a code
Post #636122 Sun Sep 24 2023 6:59pm
These things hate low battery voltages. If you're going to be using it for short journeys, it would be wise to use a smart-charger regularly to keep the battery topped up, especially as we go towards winter. If the vehicle has tow electrics fitted, you can charge through the towing permanent live using something like a CTek charger and a towing electrics adaptor.
It's a useful way to check the battery too - checking via the tow plug means you don't have to unlock the car and wake up the ECUs - so you get a proper resting battery reading. 2012 SDV6 - it's missing a couple of cylinders
Post #636127 Mon Sep 25 2023 10:33am
