Home > In Car Electronics > Audio issue - Static on every output |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 241 |
Check the amp under the passenger seat, easy to unbolt 4 bolts lift seat out, can keep the seat belt attached theres enough slack on it.
Thu Aug 24 2023 4:12pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 204 |
Hi Karl,
Fri Aug 25 2023 4:07pm |
Right, I've checked all the connectors on the back of the amp and also the earth connectors behind the kick panel, again all of them are clean.
Sat Aug 26 2023 11:45am |
f20gm Member Since: 27 Jul 2023 Location: Leeds Posts: 3 |
I have the same issue, does the touch screen grey out some of the audio selctions when the static is happening?
Wed Oct 18 2023 2:32pm |
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 |
Hi There,
Mon Oct 23 2023 8:45am |
