![]() | Home > In Car Electronics > Audio issue - Static on every output |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 273 ![]() |
Check the amp under the passenger seat, easy to unbolt 4 bolts lift seat out, can keep the seat belt attached theres enough slack on it.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi Karl,
Right, I've checked all the connectors on the back of the amp and also the earth connectors behind the kick panel, again all of them are clean.
f20gm Member Since: 27 Jul 2023 Location: Leeds Posts: 3 ![]() ![]() ![]() |
I have the same issue, does the touch screen grey out some of the audio selctions when the static is happening?
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 ![]() ![]() ![]() |
Hi There,
