Home > Faults & Fixes > gearbox serviced- now not starting
Zebdi
Hello RRS forum
I have a 2006 2.7 TDV6 RRS
I have recently changed the valve and solenoids during a gearbox service due to a fault with one of the solenoids (pulled for a working spare gearbox)
Now the car won't start. I believe the car thinks it isn't in park as I am also unable to remove the key from the ignition barrel unless I remove the battery. I have disconnected the gear linkage cable and shifted the gears back and forth a few times to try pass oil around the gearbox. I have done this with the ignition off, maybe I have to do this with power to the car to power the solenoids?
I have tested the fuses for the starter and they all seem to be working fine. I have also tested the battery and getting 12.8v so that seems to be fine.
Any ideas on what the fault might be?
Thanks for your help
Post #635215 Tue Aug 22 2023 10:14am
NoExpert
Did you get the gear potentio back into position when you put the mechatronic back in? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635223 Tue Aug 22 2023 2:13pm
Yeah good point. There is that slider on the megatronics unit that needs to be engaged or in the right posssition at the gear selection leaver.
I was going to suggest the main connector wasn’t fully seated.
Sounds like your going to have to drain the fluid and get back in there.
Post #635231 Tue Aug 22 2023 7:15pm
