![]() | Home > General > Reliability question. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Mostly yes. Regards etc.,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5013 ![]() ![]() ![]() |
Opinions vary |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Not really 😕 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
You will not find a face-lift car car with a 2.7L engine anyway, but I imagine the 3.0L is the better one. Both engines were a little suspect, the engine aside I would also be looking at how well it has been maintained, as there are a lot of bad ones out there, as people buy them, can't afford them, do the minimum amount of maintenance possible, buy the cheapest parts available and then whinge and gripe about how unreliable these vehicles are.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
As Col says, it comes down to how the individual car has been maintained. There are 2.7 with starship mileage, there are 3.0 with similar mileage. There are 2.7 that suffered failures when "young", and there are 3.0 that did likewise.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
If it doesn't have a V8 its not a proper Range Rover. |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 188 ![]() ![]() ![]() |
Thanks guy's |
Arh. Black air vents in wing.
Don't think it will be a genuine "Black Edition" although it doesn't appear to be advertised as one, as I believe they were the last of the run out model for the L320's in 2012/13.
Is that link safe ?
Early facelift. Split tailgate (I miss that on mine), 6-sp box, dynamic programme on TR so it's got the active dampers. Appears to have mismatched tyres (or a couple are quite worn) but the ones I can read are Falken so not cheapo Chinese ditch-finders (never a good sign to see cheap tyres on any car but especially these things). Hasn't got over-sized wheels (20s would be right for that RRS) which is also a good sign.
