Home > Technical > EPB Bedding in Process Now screeching |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
If you are referring to the small bias springs, I do seem to recall a note in the w/shop manual with a reference to "if fitted" so maybe not all years had them fitted for whatever reason. My car certainly had them though, one is colored green an the other red, red is left hand side and red is right hand side although can't recall what the difference is, probably the position of the retaining hooks on the end.
Sat Jul 22 2023 12:04am |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
Anyone know why my fuel gauge has now gone off? Just been stuttering and lost power aswell restarted its working but somethings not right?
Sat Jul 22 2023 3:20pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Yep, when you pull the EPB fuse it makes the car think there's no fuel. I did the same when mine stuck on.
Sat Jul 22 2023 4:35pm |
Thanks for confirming, Even if i dont put the epb on though just leave in park when i return car it automatically trys to disengage epb module so you still get a screech, Is this the car putting epb on automatically incase ppl forget? I currently have the epb cover off and following disco mikeys thread on d3 site, Im stuck with this brass end as i look at epb its on right but cant work how ppl have got it to screw back in? Its like a + spindle so no where to get a screwdriver through, tried mole grips too big. Any ideas anyone? |
Sat Jul 22 2023 5:54pm |
This is my current module, I just cant get anything on the brass to wound it in, Had anyone got any tips?
Sat Jul 22 2023 7:05pm |
Managed to get the brass loose, I had to remove module frame 4 nuts at rear and tilt forward giving me a better angle to get a long bar in with a screwdriver bit on the end and a few hammer taps and the base of the brass and it was loose, Wound it all back thats sorted.
Sun Jul 23 2023 5:11pm |
