![]() | Home > General (L494) > RRS suspension |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Just had a scan done to see what the issue is with my 2014 RRS.
I looked at the filter and mine already had a hole in it, I ordered a new one anyway which came without a hole, fitted it but made no difference.
Have you tried it without the filter,,only difference is,,is it is louder & you can hear compressor working more. Andy.
I haven't tried it without, I will try that at the weekend and see what happens |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
My Indie replaced my suspension compressor with a new Hitachi one (July 2021) - parts and labour cost = £535.80 Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
Without the filter there is a risk of crud getting in to the system and causing issues with valve blocks later down the line, I'd have thought. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
RRSTDV8,,I don’t mean for him to run it without the filter,but just to try it & see if that solves the problem. Andy.
Ah, yes, that makes sense. |
Suspension fault update
I wouldn't let a main dealer anywhere near it. They're incompetent at the best of times, downright liabilities the rest of the time. 2012 SDV6 - it's missing a couple of cylinders
Under no circumstances go near a Main Dealer. Put up a post requesting recommendations for an indie around your neck of the woods. Be prepared to travel perhaps as once you've found a good one, stick with it. 2006 2.7 TDV6 HSE in Cairns Blue. |
After speaking to a few people on forums, Ive ordered a new compressor and will be fitting it myself. |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
How will you do the software update, I guess take it to a specialist but at what cost?Will it be driveable without the update in order to get it to a garage? Tim
UPDATE.
