![]() | Home > Technical > 2nd battery ? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9024 ![]() ![]() ![]() |
It's the stop-start battery.
skullbiker Member Since: 26 Oct 2022 Location: London Posts: 8 ![]() ![]() ![]() |
Thanks for explaining that . much appreciated. I am the darkness before the storm |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Something I was going to ask myself - I have a 55plate 2.7 V6 Diesel - will that have somewhere for a second battery & if so where please ?
Yes, the L319 has a spot in front of the brake master cylinder under the big plastic cover that mimics the main battery cover. There is even a set of threaded inserts in the base of the location t allow for the holding down clamp. Also, if you look at the scuttle panel along the rear edge of the engine bay, you'll see it suits the running of a cable from the secondary location to the fusebox - there are even some useful holes for tie-wraps to secure the cable.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5043 ![]() ![]() ![]() |
Can't go there on the N/S of a 5.0 V8 petrol Sport if anybody was contemplating fitting one, as because there is a bleeding great air filter there. |
The question was about 2.7V6 Disco, Col. So it's ok for that. |
Don't think it would be worth the trouble Wayne, would need to move a ecu and some other wiring and electrics to fit anything bigger than a double AA battery in there. |
