Home > Faults & Fixes > Central locking fault on 1 door |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 145 |
Just started with this fault, fob is programmed to unlock all doors on 1 press however 3 doors unlock including boot but o/s/r door need to press fob again to unlock this door, have tried pressing both lock/ unlock on fob together to reprogram but still has same fault on door, 09 RRS, cheers [/u] |
Tue Jul 11 2023 9:41pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Had same fault on mine, same door, although a slightly later car, new door latch/lock sorted it. Not uncommon fault.
Tue Jul 11 2023 10:33pm |
Thanks Col, did you replace your self, secondhand or new, Cheers Savi18 |
Wed Jul 12 2023 4:53am |
Yeah, did it myself, bit of a pain but not to bad I actually took the outside handle off as well which makes it a lot easier, only downside is there's a good chance of breaking the retaining lugs on the small part of the external plastic cover, fortunately I had some spare one's. I fitted a genuine L/R lock/latch assembly from Advanced Factors cost me $300.00 total shipped in direct from the U.K. dealer here wanted $700.00. certainly wasn't going to chance a £25.00 ($50.00) Chinese special.
Wed Jul 12 2023 6:45am |
Thanks Col, $255 from Rimmer Bros plus shipping, will leave it till summer and sort it then.
Wed Jul 12 2023 9:07am |
