![]() | Home > Maintenance & Modifications > Advice please: Brake efficiency in hot temperatures. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Car went into the garage this morning to have the brake fluid changed and brake system checked.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Black? That doesn't sound right. There was a recall for engine oil getting in to the brake master cylinder, I wonder if yours is affected by this issue:
I've had the car over 6 years now and it's been regularly serviced with appropriately timed brake fluid changes. The braking efficiency has never given me cause for concern before, and on previous occasions the used fluid has been what would be expected. I've been here through 5 summers but the temperatures this year have increased and this is the first time I've had this problem - and only when it's been really hot of late.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I gave this some thought overnight and contacted the garage this morning.
You could always send a sample of the fluid to have it tested, there are firms that will do it for you if you are really concened about it.
Thanks Col. Barrie.
That's the plan @RRSTDV8. It will be going in for a service around the end of October and they will check it then provided all stays well between now and then.
