Home > Maintenance & Modifications > Advice please: Brake efficiency in hot temperatures. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 409 |
Car went into the garage this morning to have the brake fluid changed and brake system checked.
Mon Jul 03 2023 2:39pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Black? That doesn't sound right. There was a recall for engine oil getting in to the brake master cylinder, I wonder if yours is affected by this issue:
Mon Jul 03 2023 5:33pm |
I've had the car over 6 years now and it's been regularly serviced with appropriately timed brake fluid changes. The braking efficiency has never given me cause for concern before, and on previous occasions the used fluid has been what would be expected. I've been here through 5 summers but the temperatures this year have increased and this is the first time I've had this problem - and only when it's been really hot of late.
Mon Jul 03 2023 7:37pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
I think If engine oil is actually getting into the brake hydraulic system and contaminating the fluid, then you have a major issue as engine oil will destroy the internal rubber components/seals of the braking system. I would have thought If oil has been entering the system then the level in the fluid reservoir should have increased as well, in addition surely if oil can enter then when pressure is applied to the system brake by applying the brake pedal, fluid could possibly also be forced out.Was that recall on engine oil getting into the brake vacum servo/booster not into the system via the master cylinder?
Mon Jul 03 2023 9:57pm |
I gave this some thought overnight and contacted the garage this morning.
Tue Jul 04 2023 11:03am |
You could always send a sample of the fluid to have it tested, there are firms that will do it for you if you are really concened about it.
Tue Jul 04 2023 11:12am |
Thanks Col. Barrie.
Tue Jul 04 2023 11:50am |
That's the plan @RRSTDV8. It will be going in for a service around the end of October and they will check it then provided all stays well between now and then.
Tue Jul 04 2023 4:07pm |
