![]() | Home > Maintenance & Modifications > Advice please: Brake efficiency in hot temperatures. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hi all. I’d appreciate some advice and / or info on upgrading the brakes on my 2005 2.7 TDV6. (20” wheels)
If you wanted a cheap upgrade you could switch to the standard facelift calipers and rotors. They’re 360mm with TRW two piston sliding calipers on the front and 350mm with TRW single piston sliding calipers on the rear. You would need the carriers as well as the backplates going this route. The front backplates are easy to change, the rears are a much bigger pain. I’d start with the fronts, then when you feel like doing rear wheel bearings, do the rears.
Hi Barrie. I've had the V8 brake upgrade similar to this:
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
If the brakes are less efficient in the heat, my first point of inspection would be the fluid.
If the brakes are less efficient in the heat then there is a problem with the braking system. I live in one of the hottest populated areas of the earth and I just have standard brakes - cheapest rotors and auto shop supplied Bendix pads - no issues at all in 45c temps. 07MY RRS TDV6
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
When was the brake fluid last changed, LR do advise every three years as previously suggested probably as good a point as any to start as any, relatively easy job to do.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
No, sir, there is no energy absorption in braking. Unless you were abruptly braked by a very heavy object, then there will be energy absorbed by the object and the body of the car alike. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
They actually say DOT 4 LV. DOT 5.1 requires more frequent changes. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
Thank you all for your replies to date. Each is appreciated and you've all given me a few things to think about!
The brake fluid is given a quite brutal treatment of multiple heat cycling in a heavy vehicle such as the RRS, so changing it every 2 years is a wise choice. Regards etc.,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Ok, you're pedantically correct. I should have said "that's what converts the kinetic energy of the vehicle in to heat energy and thus gives the braking effect". ![]() 2008 TDV8 - it was a labour of love and is much missed |
You have no idea how happy I am to read this |
I could have shortened it to "that's what increases the entropy of the system" but that's perhaps a little silly here. |
So you mean it's not the "energy" exerted from my right foot on to the brake pedal, through the hydraulic system to the caliper, which pushes the piston into contact with the brake pad which creates friction with the brake disc, which in turn slows the vehicle?
