Home > General > Peculiar codes - won’t start
DirtyApe4x4
United States 2011 Range Rover Sport Supercharged HSE Santorini Black
2011 RRS GT Limited Edition, US spec petrol….Ran fine, stopped at a gas station and it wouldn’t restart. Electrics worked, dash lights would come on but no crank or clicking when operating push button start. Had it towed, just got codes back and after some personal online research I’m not finding much to go on. Any help appreciated, here is what I’ve got:
RRS codes
P0610-43 Control Module Options Error - Special Memory Failure
P0630-00 Vin not programmed or incompatible - engine control module - powetrain control module - no subtype information
U0167-00 lost communication with vehicle immobilizer control module - no subtype information 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
2009 Jaguar XK Convertible Diamond Edition/Pearlescent White 4.2 Liter
Post #633869 Thu Jun 22 2023 6:21am
well it looks very much like an imboliser problem.
If that U code comes back quickly after clearing and trying to start, it can't talk to the imboliser unit. Didn't know they had a seperate unit
Post #633874 Thu Jun 22 2023 11:06am
The first code in part refers to corrupt software flash to the CJB and or the Engine Control Module, the second one mentions a new ECM and or the CJB not cofigured correctly. Which seems a little odd unless anythings been changed recently, unless the the third one somehow has caused the first two.
Post #633875 Thu Jun 22 2023 11:56am
Disco_Mikey
Re: Peculiar codes - won’t start
Corrupt engine control module software flash
Corrupt rear junction box software flash
Corrupt central junction box software flash
Using the manufacturer approved diagnostic system check and install latest relevant level of software to the engine control module
Re-configure the rear junction box using the manufacturer approved diagnostic system
Re-configure the central junction box using the manufacturer approved diagnostic system
If the above does not cure the issue, it is possibly a corrupt CCF file. I have (in the past) had to reupload the CCF without changes, to cure problems...
Post #633892 Fri Jun 23 2023 12:30pm
jimbg
It sounds like it a modified Sport as there was never a GT Limited Edition from Land Rover. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #633894 Fri Jun 23 2023 1:41pm
