![]() | Home > General > Peculiar codes - won’t start |
well it looks very much like an imboliser problem.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The first code in part refers to corrupt software flash to the CJB and or the Engine Control Module, the second one mentions a new ECM and or the CJB not cofigured correctly. Which seems a little odd unless anythings been changed recently, unless the the third one somehow has caused the first two.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Corrupt engine control module software flash Corrupt rear junction box software flash Corrupt central junction box software flash Using the manufacturer approved diagnostic system check and install latest relevant level of software to the engine control module Re-configure the rear junction box using the manufacturer approved diagnostic system Re-configure the central junction box using the manufacturer approved diagnostic system If the above does not cure the issue, it is possibly a corrupt CCF file. I have (in the past) had to reupload the CCF without changes, to cure problems... |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1876 ![]() ![]() |
It sounds like it a modified Sport as there was never a GT Limited Edition from Land Rover. 2023 P440e SE Dynamic on order -cancelled
