![]() | Home > Technical > 2006 RRS Height Question |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1878 ![]() ![]() |
You can simply lock it in access height as you approach via the console switch. 2023 P440e SE Dynamic on order -cancelled
With 18 mm of clearance (and here's hope the car is on standard size tyres and the measuring tape for the garage door was accurate) I would definitely make it a very slow approach |
No, just take a run at it! |
Pete8777 Member Since: 21 Jun 2023 Location: UK Posts: 2 ![]() |
Thank you for the replies.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
Seams to be measured to the shark fin. So you should have a fair clearance ? |
