Home > Technical > 2006 RRS Height Question
Pete8777
Hello,
Looking to get a 2006 RRS 2.7
The thing I may have an issue with is the garage door height. I am not sure I will get it in the garage.
I can find specs online that give a height but I don't know what the suspension setting is at when they took that height measurement.
Does anyone know what the lowest height the car can go for parking in the garage? Its ok when its through the door but want to make sure it will actually get in there.
The distance from floor to garage door is 178cm
Thank you
Post #633854 Wed Jun 21 2023 5:58pm
TheWojtek
 Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633856 Wed Jun 21 2023 7:28pm
jimbg
You can simply lock it in access height as you approach via the console switch. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #633857 Wed Jun 21 2023 7:34pm
TheWojtek
With 18 mm of clearance (and here's hope the car is on standard size tyres and the measuring tape for the garage door was accurate) I would definitely make it a very slow approach Rolling with laughter Regards etc.,
Wojtek
Post #633858 Wed Jun 21 2023 7:44pm
jimbg
No, just take a run at it! Whistle Whistle 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #633859 Wed Jun 21 2023 7:46pm
Pete8777
Thank you for the replies.
Wow that is going to super tight. Its not on standard wheels, its on 22's. Though the overall diameter should be the same as standard.
I could get my Freelander in ok, just. But looks like I might struggle here :/
Post #633860 Wed Jun 21 2023 8:04pm
Seams to be measured to the shark fin. So you should have a fair clearance ?
Post #633865 Wed Jun 21 2023 10:29pm
