Home > Technical > Coolant Leak Location? |
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 |
Sorry didn't tap upload button! |
Mon Jun 12 2023 6:37am |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 37 |
if this is aL494 look at the tiny venting pipe goes from the header tank to the radiator, the o ring on it gets damaged and causes leak. I just repaired mine |
Mon Jun 12 2023 6:32pm |
Thanks RRS4ED!
Mon Jun 12 2023 7:20pm |
NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 483 |
Define āseems to beā. The skid plate has a weep hole on the left side as you face the engine. So that can be fooling you into looking in the wrong place. Iād look at the water pump and the coolant outlet at the top front thatās between the heads and oil cooler. After that Iād start checking hoses and then the EGR cooler hoses. Last stop would be the oil cooler between the heads. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Jun 14 2023 10:39am |
Thanks mate,
Wed Jun 14 2023 10:48am |
the expansion tank i was on about, i am not sure setup of L320 but on my L494 it was the o ring for the pipe came from the expansion tank, which is for the vent.
Sun Jun 18 2023 7:44pm |
finally got around to looking more deeply into this and everything coolant system based seems to be dry (all hoses, water pump, radiator etc)
Mon Jul 10 2023 9:30am |
Think I found it now, nevermind! |
Mon Jul 10 2023 11:09am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
And it was..............? 2023 P440e SE Dynamic on order -cancelled
Mon Jul 10 2023 12:09pm |
When doing other work a while back I refitted the EGR coolant hose that runs across the top of the accessory drive belt area too low. It began rubbing on the viscous fan mount and made a tiny hole in the hose.
Mon Jul 10 2023 12:36pm |
