Home > General (L494) > Oil warning lamp
Martin Mole
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Oil warning lamp
I apologise if this is a numpty question. my 2014 RRS 3.0 SDv6 appears not to have an oil pressure warning light! Every other car I've owned that light comes on with ignition and goes out when engine running. Only noticed this when doing an oil and filter change (looked to make sure it went out) but it's never on.
If it should be on with ignition can anybody give me a pointer as to where the oil pressure switch is so I can check the wiring there.
Thanks in anticipation.
Post #633361 Thu May 25 2023 4:22pm
Disco_Mikey
It's ECU controlled. The LCD will display the warning when the oil pressure drops below a preset level for a defined period of time
By which time, its probably too late anyway...
Post #633363 Thu May 25 2023 7:19pm
Martin Mole
Oil warning lamp
Thanks for that mate, after all these years of owning different cars still something new to learn.
Post #633366 Fri May 26 2023 6:20am
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I check my oil level once a month, it’s not using any just a precaution, bring back the good old dipstick where you could actually see the oil level.
Post #633367 Fri May 26 2023 6:52am
