Home > General > Front door won't open unless put hand in handle
pbcb2020
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Car had front passenger door lock replaced as it wouldn't lock by an Indy.
Then on way back wife put window down and we heard a clunking,cracking noise briefly but then went down and back up. Tried again and no noise
When got home, she couldn't open the door using the latch. I tried pressing the unlock on fob and drivers side unlock button, but to no avail. The unlock lock part to latch seems stiff and doesn't move when press any unlock way.
Walked round and couldn't open the door from outside either.
Upshot is only way to open the door now is to have key fob next to door handles outside, put hand inside handle, hear a click and then you can open it from outside, but still not inside
Any help please 🙏
Garage have changed the locking system but still same but I'm sure it's the latch inside as heard crunch when window lowered and was able to open door inside and out before lock changed and window put down
Post #633171 Thu May 18 2023 6:27pm
Sounds a bit like the release cable from from the internal handle to the latch may have snapped, disconnected somehow or not refitted correctly when lock changed, not sure if the window linkage could catch the cable in someway when it went down if the cable had not been fitted/secured correctly, only a suggestion though, would need to remove door trim panel to have a look.
Post #633182 Thu May 18 2023 10:07pm
Disco_Mikey
It it doesn't unlock with the key fob, but unlocks with the Keyless system, then its more than likely a faulty latch
Was it a genuine replacement, or aftermarket ?
Post #633183 Fri May 19 2023 5:28am
pbcb2020
Appreciate the reply Disco_Mikey.
The lock was a genuine part from Stradstone. They never changed the latch.
Could those of got damaged when the window was lowered ? If say the garage left a wire loose etc from when they did the new lock as it made an awful cracking noise when window went down?
They seem to think it's electrical but after hearing that crunching noise When we lowered window 1st time, after having lock changed, I'm sure it's something manual if you get me like what you said.
The internal latch is alot tighter than all other and internal lock button won't move if you press unlock and even manually stiff and does nothing 😑
Post #633190 Fri May 19 2023 8:49am
The internal release lever is connected to the latch by a short bowden cable not a electrical cable, bit like a very short pushbike brake cable for want of a better description.
Post #633191 Fri May 19 2023 8:55am
pbcb2020
Thanks. Is that something I could look at ? And do you need to take whole door unit off, similar to what need to do ro replace the lock unit
Post #633231 Sun May 21 2023 2:52pm
You will need to remove the door trim panel to get to it, not the whole door though Laughing
Post #633248 Sun May 21 2023 9:04pm
