Home > Wheels & Tyres > Anyone running spacers on their L320 RRS?
wiztaz
Hi Guys,
Anyone got spacers on their RRS S/C L320? I was thinking about adding 15/20mm only in the rear and wanted to understand if anyone has had any problems?
Thanks
Post #620906 Thu Jan 13 2022 4:57pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
I had some 10mm knocking around so fitted them to the rear to see how it looked much improved but a little close on the threads so you need bolt on spacers and the thinnest I’ve found are 20 and 25mm. This is what I’ll be fitting soon. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #620915 Thu Jan 13 2022 8:09pm
chrbro
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Don't just don't rear wheel spacers will wear out your front tyres on the inside edge inside 8000 miles. Rest of tyre ok but down to cores on inside edge
Post #632995 Wed May 10 2023 11:04pm
I wouldn't really know, but that sounds more like a alignment issue rather than being caused by the spacers, but I guess it's always possible.
Post #632996 Thu May 11 2023 10:10am
JonnyCJ
I think inner wear is caused by a lot of full lock putting the full weight of the front end on a very small contact patch. Just had this on SWMBOs Merc ML.
Popped a set of Accelera Iota’s on the front of the ML and did nearly 450 miles on them yesterday. Have to say I was mightily impressed with the road noise (low). Tyre review sites also give them a good score.
Post #633140 Wed May 17 2023 10:08pm
I would have been inclined to think if both tyres are wearing on the inside edges that would be more to having to much toe out or negative camber angle, outside edges would be to much toe in, if it was related to to much steering lock would it not be on both inner and outer edge depending on left or right lock as you would in effect trying to push the tyre sideways, and the outer edge on one tyre would be trying to roll under and the inner edge on the opposite tyre trying to do the same, depending on left or right hand lock.
Post #633141 Wed May 17 2023 11:13pm
JonnyCJ
Hi Col - in SWMBOs case it was inner and outers that were severely worn.
Post #633145 Thu May 18 2023 6:41am
