Home > Technical > Long term fuel trim gone crazy
The outsider
Hi my 2005 rrs 4.2 s/c is not playing right. Plug it in and noice my long term fuel trim is all over the place. Got the car cheap and really want to get her running right. All help would be much appreciated
Bank 1 -11
Bank 2 + 15
Post #633041 Sat May 13 2023 9:45pm
Air leak on one slide maybe
You may hear it even
Post #633048 Sun May 14 2023 8:33am
The outsider
Thanks for the reply. Looks like my Pcv valve and hose is leaking. And I had a coil that was not in properly. Previous owner tightened the 8mm bolt to tight and pulled the nut out the rocker cover. Is there any video around that show you how to take the hose off as it look like it disappeared into the back of the engine
Post #633049 Sun May 14 2023 9:15am
Picture of hose routing if of any help.
Post #633051 Sun May 14 2023 9:40am
The outsider
Yes thank you helps a lot 👌
Post #633067 Mon May 15 2023 11:17am
