Home > Technical > Long term fuel trim gone crazy |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4939 |
Air leak on one slide maybe
Sun May 14 2023 8:33am |
The outsider Member Since: 13 May 2023 Location: London Posts: 3 |
Thanks for the reply. Looks like my Pcv valve and hose is leaking. And I had a coil that was not in properly. Previous owner tightened the 8mm bolt to tight and pulled the nut out the rocker cover. Is there any video around that show you how to take the hose off as it look like it disappeared into the back of the engine |
Sun May 14 2023 9:15am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4967 |
Picture of hose routing if of any help.
Sun May 14 2023 9:40am |
Yes thank you helps a lot 👌 |
Mon May 15 2023 11:17am |
