![]() | Home > Maintenance & Modifications > Suspension confusion.. |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
An update !
Quite literally an overnight success.
Please for u |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Great. Well done and thanks for the details around the issue and repair. |
My pleasure - what it’s taught me is that the suspension isn’t rocket science. There’s a pump, a tank, pipes, valve blocks and air bags. If you can isolate what’s causing the problem then generally it’s an easy fix.
And still it holds pressure without dropping a single mm, even after a week.
