Home > Maintenance & Modifications > Suspension confusion.. |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 348 |
An update !
Fri May 12 2023 8:50pm |
Quite literally an overnight success.
Sat May 13 2023 7:19am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Please for u |
Sat May 13 2023 7:23am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 409 |
Great. Well done and thanks for the details around the issue and repair. Barrie.
Sat May 13 2023 10:41am |
My pleasure - what it’s taught me is that the suspension isn’t rocket science. There’s a pump, a tank, pipes, valve blocks and air bags. If you can isolate what’s causing the problem then generally it’s an easy fix.
Sat May 13 2023 11:07am |
And still it holds pressure without dropping a single mm, even after a week.
Tue May 23 2023 9:51pm |
