Home > In Car Electronics > 2010 Facelift wiring diagrams
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Yes I also believe one fault is causing the other.
The sensor modules are different on the facelift versions, so the wiring my also differ.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632985 Wed May 10 2023 6:50am
I did find these two, they are for the facelift so they might apply to your vehicle, they don't really show much, Iwill have better look at some others when I have a bit more time. If you click on them in "my gallery" they will show up better. Not a auto electrician but looks to me as if a lot of the work is done within the CJB/BCM but could well be wrong on that one. The code does suggest the possibility of a faulty module, but that could be a rather expensive trial and error test unless you are sure it is faulty.
Post #633000 Thu May 11 2023 10:27pm
Jabba
Hi Col,
Many thanks for your time on this, much appreciated.
Yes, I looked for a replacement sensor and the secondhand ones are expensive let alone looking at a new price.
I know these sensors can be damaged from being knocked/dropped. There's some paint missing in the centre of my front bumper, just on the lower edge above the number plate. It could have received damage but I must remove the bumper to really take a look.
The fault is strange, as I said if I active the sensor in the menu, it will error on every journey but not straight away. If I cycle the ignition after the error, it clears and I can use the sensor again without fault on that journey. I'm hoping for a wiring fault/corrosion, but I won't know until I get the bumper off.
Sorry, where do you get the wiring diagrams from ?
Many thanks
Post #633006 Fri May 12 2023 12:29pm
The diagrams I do have are what I have downloaded from Topix over time for various reasons, If you take out a subscription with Topix you can download them, plus any other stuff you might want for the rest of for your vehicle, the only problem is now I think you can only download one page at a time, whereas you were able to do it in sections, but I could be wrong on that as I haven't used it for a while, just another L/R trick to make people pay more, and making it more time consuming for others to download it, copy it and sell on the likes of fleabay.
Post #633022 Fri May 12 2023 10:20pm
Jellis39
I have a similar issue which started this afternoon. I have no codes though which is very strange. Get the message for not available and adaptive cruise light flashing amber.
Post #634148 Thu Jul 06 2023 8:21pm
