![]() | Home > Technical > Approach / welcome lights under the wing mirror question |
drexal Member Since: 17 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hi guys,
Hey Andy K thanks for replying, ahh i don't think i tried moving the door open and close back&forth etc to check this. But both lights in left and right door mirror do the same thing. So i don't think its broken wiring, but i will go down and check this later.
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 493 ![]() ![]() ![]() |
You need load resistors like what Osram offers to get the right wattage draw. Same with the puddle lights in the bottom of the front doors. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
I would have thought they would work with load resistors. Just fade differently o |
Hi no Expert, thanks for replying. Powerful Uk the supplier hinted at this, but they said you really only need a resistor change when you've replaced every single bulb to LED interior and exterior, but they said you don't really need this when just replacing the mirror light and number plate lights. Also they work fine when the front doors are open. Its only when the doors are shut, they won't turn on or they just flash on for a second.
Hey Andy,
The mirror lights and the puddle lights on the front doors are controlled by modules in the doors which look for load. None of the other bulbs require it as theyâre run off the CJB (Iâve replaced every W5W bulb in my car with Osram LEDâs). The load resistors are easy to install and pretty small. If you get the Osram units they come with everything needed to install them. They just bridge across the positive and negative wires, so not much effort, just plan where the clips go so you donât end up with a big bulge of connectors.
If I turn off the interior lights at the overhead console the only lights that work are the ones in the bottom of the front doors, lower passengers glovebox and those in the vanity mirrors, the ones in the mirrors only work along with the others if the interior lights are set in the on position via the console button.
Hey Col,
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
Hi drexal, just wondered if you have managed to resolve your issue.
The answer to that question is no and no.
Hi Col,
Hi, sorry should have said the lights are not controlled by a sensor and work in daylight as well.
Thanks Col |
