Home > Technical > Tracking issue after new arms
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi all, just had two new bottom arms fitted along with all new bolt hardware. Then had it 4 wheel tracked. Problem arises on drivers front in that they can't get the camber 100% bang on as the new bolts only push out so far before coming in again. They suggest that it is wear to the bolt hole where it may be slightly oval. It drives fine and straight but been told to look out for possible inner tyre wear.
Is there a part I can change to rectify this properly?
Post #632528 Thu Apr 20 2023 3:57pm
gogsy1956
Just curious as to where you got the alignment done? 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #632547 Fri Apr 21 2023 6:11pm
The brackets with the adjusting holes in are welded to the frame so technically they are not replaceable, certainly would not be available from L/R. It may be possible to build the worn edge up with weld and file back down to original size. I would be more inclined to check the ''Lug's'' the adjusting washer's ride/rotate against to make sure they haven't been damaged as well, possibly by someone having done a previous alignment.
Post #632553 Fri Apr 21 2023 9:26pm
Toonraider
Tracking was done at Tyrespot, friend of a friend. Took all my other vehicles there with no issue. These were brand new arms and all new bolt hardware.
Any chance of a pic showing these Lugs?
Post #632562 Sat Apr 22 2023 7:48am
Not the best picture, but that's all they are and the concentric washers rotate against them, if they have been damaged or sort of flattened in anyway the washers can ride over them and not allow the bolt to adjust properly.
Post #632563 Sat Apr 22 2023 8:15am
Toonraider
Thanks for the pic Col. Very speedy of you. When it stops raining I'll hopefully get a chance to have a look.
Post #632565 Sat Apr 22 2023 8:36am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
That's exactly what has happened on our D3 iv got to weld a small plate on at some point the alignment place I used saidxalmost the exact same thing.... the holes in the chassis must be worn out Rolling with laughter
Post #632566 Sat Apr 22 2023 8:48am
Toonraider
Ah right. Good idea.
Post #632567 Sat Apr 22 2023 8:58am
Toonraider
But then again. Where to weld the bit on?
Post #632648 Mon Apr 24 2023 12:11pm
As you can see the '' Lugs'' quite easily from under the vehicle, if the n/s one is o.k. then you should be able to take a measurement from that to position, as where to weld a new plate too, or as the original is only basically a indentation stamped in the metal you could probably work it out by looking on the inside of the bracket to see the where the indentation was stamped in. If indeed that is the cause of your issue.
Post #632657 Mon Apr 24 2023 10:11pm
Toonraider
Yep, good logic there, cheers.
Post #632660 Tue Apr 25 2023 6:19am
erickwan
Malaysia
Are these original Land Rover arms?
Post #632775 Sun Apr 30 2023 3:41pm
Toonraider
Yep, sure are. All sorted yesterday. Followed the advice of above and the alignment advice about correct neg degree camber post.
Post #632776 Sun Apr 30 2023 3:51pm
