Home > Technical > Tracking issue after new arms |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Just curious as to where you got the alignment done? 2010 RRS, TDV8
Fri Apr 21 2023 6:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4967 |
The brackets with the adjusting holes in are welded to the frame so technically they are not replaceable, certainly would not be available from L/R. It may be possible to build the worn edge up with weld and file back down to original size. I would be more inclined to check the ''Lug's'' the adjusting washer's ride/rotate against to make sure they haven't been damaged as well, possibly by someone having done a previous alignment.
Fri Apr 21 2023 9:26pm |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Tracking was done at Tyrespot, friend of a friend. Took all my other vehicles there with no issue. These were brand new arms and all new bolt hardware.
Sat Apr 22 2023 7:48am |
Not the best picture, but that's all they are and the concentric washers rotate against them, if they have been damaged or sort of flattened in anyway the washers can ride over them and not allow the bolt to adjust properly.
Sat Apr 22 2023 8:15am |
Thanks for the pic Col. Very speedy of you. When it stops raining I'll hopefully get a chance to have a look. |
Sat Apr 22 2023 8:36am |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 341 |
That's exactly what has happened on our D3 iv got to weld a small plate on at some point the alignment place I used saidxalmost the exact same thing.... the holes in the chassis must be worn out |
Sat Apr 22 2023 8:48am |
Ah right. Good idea. |
Sat Apr 22 2023 8:58am |
But then again. Where to weld the bit on? |
Mon Apr 24 2023 12:11pm |
As you can see the '' Lugs'' quite easily from under the vehicle, if the n/s one is o.k. then you should be able to take a measurement from that to position, as where to weld a new plate too, or as the original is only basically a indentation stamped in the metal you could probably work it out by looking on the inside of the bracket to see the where the indentation was stamped in. If indeed that is the cause of your issue.
Mon Apr 24 2023 10:11pm |
Yep, good logic there, cheers. |
Tue Apr 25 2023 6:19am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
Are these original Land Rover arms? |
Sun Apr 30 2023 3:41pm |
Yep, sure are. All sorted yesterday. Followed the advice of above and the alignment advice about correct neg degree camber post. |
Sun Apr 30 2023 3:51pm |
