Home > General (L494) > Roof rail covers |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 256 |
I did a search but didnt come up with anything.
Mon Apr 17 2023 11:20am |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
Not sure if this helps (extract from the LR fitting instructions for L494 roof rails). Looks like you need a trim removal tool with a split blade.
Mon Apr 17 2023 8:59pm |
Many thanks, I only need to remove the covers to access the drains.
Tue Apr 18 2023 9:39am |
Thanks, but if I can locate the drain tube exit, could I feed something upwards such as a strimmer line to clear out any blockage?
Mon Apr 24 2023 10:15am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 233 |
There pretty strong to be fair, you need to stick a trim popper tool underneath with a cloth underneath the side closest to edge of the car so you don't mark you paint work, then work the trim popper from one end of the car to the other, lay the trim tool flat then turn it 90 degrees so it lifts the trim up and off.
Mon Apr 24 2023 11:21am |
Thanks, will give it a go. RRS HSE Dynamic SDV6 2014
Fri Apr 28 2023 2:58pm |
