![]() | Home > Tips & Tricks > Which adhesive for interior trim A & C pillars |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
It's an age old problem that requires an age old glue, I use copydex with good results. I did recover my A pillars with matching fake leather tho.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I think the nature of the material most adhesives will bleed through, I don't know if it would work or not but if it's only on the edges 3M used to do a very thin double side tape for automotive use no thicker than normal sellotape but is extremely strong bonding, I have used it on rubber and plastic and works well, unfortunately although I have some here there is no product code on it.
Thanks both for your replies |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
The material on the roof of the cabin started to sag on mine. The garage who does all my work and who have got a great reputation for restoring all makes and models said they cannot / would not glue it as there is no adhesive to give it a truly professional finish. He said the only option was to fit new headlining. I guess you could use any glue but the end product might not be as good as we'd like. Barrie.
Honestly just recover them
3rr Member Since: 13 Oct 2011 Location: Melbourne Posts: 6 ![]() ![]() |
Gluestick from newsagent in LR we trust |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
Use a high temperature contact adhesive.
