Home > Technical > Service Kits - Any Advice Regarding Supplier/Manufacturer |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
The Britpart kits are fine (we use them on a daily basis in the workshop) but make sure you get the OEM version, and use a good quality 5W30 oil |
Sun Mar 26 2023 12:55pm |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 204 |
That's the problem DM....there is so much choice regarding the oils, the kit i'm looking at has Rock oil, other kits have Miller oil or QX or Castrol....if they all match the spec required whats the difference?? 2015 L494 SDV6 3.0 HSE Loire Blue
Sun Mar 26 2023 1:04pm |
Out of those, I'd go for Castrol
Sun Mar 26 2023 1:09pm |
Thanks Mikey......bloody minefield oil choice 2015 L494 SDV6 3.0 HSE Loire Blue
Sun Mar 26 2023 1:10pm |
Used to use Shell oils, then we moved to Comma |
Sun Mar 26 2023 1:12pm |
Ok.....seen a kit with Comma oil, what about Mannol, any good?
Sun Mar 26 2023 1:47pm |
Apparently...
Sun Mar 26 2023 3:53pm |
Thanks for the advice Mikey
Sun Mar 26 2023 4:13pm |
That's not an OEM kit... |
Sun Mar 26 2023 7:15pm |
I just cross checked the part numbers of the one you recommended above and the one i ordered,
Sun Mar 26 2023 7:27pm |
DA6037P isn't what you've linked to.
Sun Mar 26 2023 7:30pm |
yup.....asked them to cancel order and i'll order the OEM kit 2015 L494 SDV6 3.0 HSE Loire Blue
Sun Mar 26 2023 7:34pm |
