![]() | Home > General > Satnav screen gear select letter / L320 gen1 workshop manual |
Dunc101 Member Since: 16 Nov 2017 Location: Bedfordshire Posts: 32 ![]() ![]() ![]() |
Hi all - I’ve got a 2007 gen1 RRS TDV8 and love it. I’ve recently taken the plunge and upgraded the steering wheel to the 2010 version - taking the opportunity to treat myself to a heated steering wheel and flappy paddle gears also 😉🙌🏻, and I’ve upgraded the sat nav screen to the 2010 version.
Very odd and annoying.
Hi Andy K - yes to both : unusual and annoying! Lol.
You need to select my10 for the camera with gap iid
Thanks Andy K. Yes, I’ve enabled that with the IID tool.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
If I recall correctly, pre-facelift RRS does not inform the post-facelift screen it is in reverse in a manner this screen expects. Something with CAN messages, either this very information was realized without CAN or was transmitted on a CAN bus that is not available to the screen. Regards etc.,
Hi TheWojtek - thanks, that may be the case, but the issue was first noticed with the original gen1 screen, and also with a different gen1 screen installed to test. This issue has then followed to the gen2 screen. Because the issue is repeated on three different screens, I’m confident that’s not the issue.
Good news Andy K - I’m guessing the gear letters on your screen work also, ie the screen knows it’s in reverse, so switches the feed to video (reverse cam) |
That is correct |
