Home > In Car Electronics > GPS disk? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5008 |
But do you have the navigation computer under the seat? as would have thought navigation would be a option on the "S" as well.
Sat Mar 04 2023 1:09am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4990 |
Op. Try putting your old disc in and see if voice returns. |
Sat Mar 04 2023 9:07am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
2008 or 2009 disc had a firmware update, this feature should be working straight out the box in a 2005, though. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Mar 04 2023 9:37am |
OK, great lead. Do you have the satnav as well or 4x4 info only? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Mar 04 2023 9:39am |
And do you have factory Bluetooth and what code do you enter to pair? 2121 or |
Sat Mar 04 2023 10:14am |
If the car hasn't got navigation then the voice recognition software is in the phone transceiver module.
Sat Mar 04 2023 10:26am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 328 |
Col - I think Wojtek's comment refers to my 2006 Sport were the computer is under the front seat. Andrew Andrew Kennedy |
Sun Mar 05 2023 9:55am |
Hi, my mistake and getting a little side tracked, I was actually asking savi18 if he had the navigation computer under the seat as the "S" didn't have it as standard, but he does have voice recognition otherwise the software is in the transceiver module for the phone.
Sun Mar 05 2023 11:21am |
Hi Col. Side tracked?...I'm a little confused! To summarise the discussion re by "Voice Recognition" paddle is not working. Are we saying the Voce Recognition is nothing to do with the GPS system? And I should be looking ells ware to solve the problem? I had presumed, wrongly it would seem, that the two functions were linked to the Disk Andrew Kennedy |
Sun Mar 05 2023 1:43pm |
Try this, as you use your phone for Nav
Sun Mar 05 2023 4:46pm |
Sorry Andy - try what? no suggestion came with your post. Andrew Kennedy |
Sun Mar 05 2023 5:04pm |
Put the old disc in |
Sun Mar 05 2023 6:05pm |
What I was saying is, if you have the navigation unit under the seat the voice recognition software is installed in that, if you don't have the navigation computer it is installed in the phone transceiver module which is located behind the r/h panel in the boot, whether updated software/firmware if required can be installed by using the latest genuine disc I don't know or if it can be done using a gap tool or sdd. You maybe able to find the current version via. the 753 menu but not sure on that either, but you still need to know the latest version number to compare if req.
Sun Mar 05 2023 7:34pm |
