Home > In Car Electronics > GPS disk?
But do you have the navigation computer under the seat? as would have thought navigation would be a option on the "S" as well.
Post #631332 Sat Mar 04 2023 1:09am
Sometimes you will install a new map disc and it will also update firmware in the unit too.
You also hear about later map discs not containing all the data that a LR disc would have. And thus voice doesn’t work.
I think you have to accept it doesn’t work and move on. Im sure phones can take voice notes
Post #631333 Sat Mar 04 2023 8:57am
Op. Try putting your old disc in and see if voice returns.
Post #631334 Sat Mar 04 2023 9:07am
TheWojtek
2008 or 2009 disc had a firmware update, this feature should be working straight out the box in a 2005, though. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #631336 Sat Mar 04 2023 9:37am
TheWojtek
savi18 wrote:
My 2009 RRS is only a S model and does have the voice control.
OK, great lead. Do you have the satnav as well or 4x4 info only? Regards etc.,
Wojtek
Post #631337 Sat Mar 04 2023 9:39am
And do you have factory Bluetooth and what code do you enter to pair? 2121 or
Post #631339 Sat Mar 04 2023 10:14am
If the car hasn't got navigation then the voice recognition software is in the phone transceiver module.
Post #631340 Sat Mar 04 2023 10:26am
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Col - I think Wojtek's comment refers to my 2006 Sport were the computer is under the front seat. Andrew Andrew Kennedy
Post #631364 Sun Mar 05 2023 9:55am
Hi, my mistake and getting a little side tracked, I was actually asking savi18 if he had the navigation computer under the seat as the "S" didn't have it as standard, but he does have voice recognition otherwise the software is in the transceiver module for the phone.
Post #631366 Sun Mar 05 2023 11:21am
andrew kennedy
Hi Col. Side tracked?...I'm a little confused! To summarise the discussion re by "Voice Recognition" paddle is not working. Are we saying the Voce Recognition is nothing to do with the GPS system? And I should be looking ells ware to solve the problem? I had presumed, wrongly it would seem, that the two functions were linked to the Disk Andrew Kennedy
Post #631370 Sun Mar 05 2023 1:43pm
Try this, as you use your phone for Nav
Post #631375 Sun Mar 05 2023 4:46pm
andrew kennedy
Sorry Andy - try what? no suggestion came with your post. Andrew Kennedy
Post #631379 Sun Mar 05 2023 5:04pm
Put the old disc in
Post #631383 Sun Mar 05 2023 6:05pm
What I was saying is, if you have the navigation unit under the seat the voice recognition software is installed in that, if you don't have the navigation computer it is installed in the phone transceiver module which is located behind the r/h panel in the boot, whether updated software/firmware if required can be installed by using the latest genuine disc I don't know or if it can be done using a gap tool or sdd. You maybe able to find the current version via. the 753 menu but not sure on that either, but you still need to know the latest version number to compare if req.
Post #631386 Sun Mar 05 2023 7:34pm
