![]() | Home > Technical > 2012 Headlight dip/high beam mismatch. |
The flat beams are a 2012/2013 item, they’re distinguished by the black inner trim as opposed to the 2010/2011 grey inner trim.
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 49 ![]() ![]() ![]() |
My projectors don't seem to match any of the descriptions, in the manual or what you are each saying.
Managed to get some awkward pics.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I would assume the spring thing is to select main beam.
Eh, no.
Eh, no.
There is a flap. Normally the top of the beam is blocked off.
Here's more of a closeup of that shield mechanism.
Apologies. Zenon IS a dip/main beam. Covered the main reflectors and without the engine running I can hear and see the zenons changing with the dipswitch. I wouldn't have said my dip is "flat", but it certainly only angles up slightly to the left. Looks like the dopey idiots have just lowered the whole dip to avoid problems when driving on the right. The dips are so short that I had to slow down on the motorway, because I couldn't see far enough ahead to stay in lane when there was nobody in front to light the road. Cretins. I bet there was a consultant involved in this. Probably more than one. Do the earlier headlights with the conversion shield / lever have a more realistic dip? Alan Series 3 109 Classic 2-door 101FC GS Three P38 4.6L RRS mk1 2012 |
I know the discovery lights got worse as the years went on.
I doubt these would blind a hedgehog at 30 feet.
Thoughts
Correct aim is 1.2% or 12cm down from level at 10 meters distance.
If the top of the headlamps has a label that states AFS - Then I would say you have a fault with the system that needs fixing (or fit non AFS lights!)
