Home > General > Looking to purchase a L320 TDV8 - advice needed
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
I'm currently looking to purchase a L320 TDV8 fadcelift.
I looked at two yesterday, the first one was 2010 plate, private owner. He has had the turbos replaced recently and a fresh MOT, it's covered just over 100K miles. All the paperwork is in order, regular serving etc. The car itself is nice, the owner lives in the countryside, so you can see the odd light bush scratches on the sides, no doubt they would polish out. Unfortunately he had a puncture the day before and swapped it for the spare until he gets a new tyre fitted. The wheels fitted are 20" but the spare is 19". He said before the test drive that the odd sized wheel, on the front, has caused the gearbox to only allow the first three gears in auto mode but the other three can be selected in command mode. The test drive proved this. I just wanted to confirm that this would be be the case wiith odd sized wheels on the front ?
The second one was a 59 plate, covered around 120K, looked really clean both inside and out, the odd mark here and there but then they're getting on a bit now. The owner, a dealer from home, said he'd spent about £4500 on the car to get the problems resolved. The suspension, when selecting access mode, it would go down then straight back up again. After a garage swapped the height sensors etc, a specialist found that the front shocks had gone hard/stiff and needed replacing. Apparently the car has, so I was told, special suspension fitted, not the same as the others and both front units cost £1600 to supply, he said they were dynamic double shocks, is this correct ?
Also the gearbox didn't change up to the last three gears, apparently his gearbox guy said it was the module and replaced it, but the fault persisted. Anyway according to the delaer, it was a wheel sensor. The test drive was great, very quiet, smooth etc, I plugged in my IID tool and found the following:
P0407-21 (2F) Exhaust gas recirculation sensor B circuit low - General signal failure - signal amplitude<minimum
I advised the chap and he said well it drives fine and theres no dash lights on, so he wouldn't entertain resolving it or a price drop.
Both cars are resonably priced, just wondered what you guys think.
Many thanks
Craig
Post #631050 Thu Feb 23 2023 7:34am
Certainly walk away from the second one that sounds like a total load of bulls**t to me. With the first one check the tyre size as some cars came with a 255/50 x 19 spare which is a compatible diameter with the 20's which would throw that gear selection therory out the window.
Post #631051 Thu Feb 23 2023 7:44am
TheWojtek
Re: Looking to purchase a L320 TDV8 - advice needed
If I were to sell the car and had a puncture, I'd do everything that I possibly can to bring the car into proper shape before showing it to a prospective buyer.
Come again once he sorts it out and take the car for a drive, seek another one if the transmission still works in 1-3 only.
The other one is BS. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #631054 Thu Feb 23 2023 8:35am
Jabba
Many thanks for your reply Col.
Yes I must admit I was a little dubiuos of the dealer, it just didn't sound right, but I wasn't sure if there were any 'special' suspension systems made, not that I could find anything about them.
The first one, the 19" spare alloy is a different style to the 20" ones fitted, I must admit I didn't check the tyre size. The owner is going to get a new tyre fitted this weekend and I've arranged a more indepth viewing on Monday, and a longer test drive. I guess we'll see what happens then.
Once again many thanks for your reply.
Craig
Post #631055 Thu Feb 23 2023 8:39am
Jabba
Come again once he sorts it out and tak the car for a drive, seek another one if the transmission still works in 1-3 only.
Hi, yes thats exactly what I am doing.
To be fair the guy had the puncture the day before, he did call me the evening before I was veiwing to tell me what had happened, which was good of him. See whats happens Monday.
Many thanks
Post #631057 Thu Feb 23 2023 8:42am
Dave B
This has been put into storage for the last couple of months, so mileage only a little more (less than 200 miles), and will come with a new MOT.
https://www.rrsport.co.uk/forum/topic60200.html
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #631058 Thu Feb 23 2023 8:59am
NoExpert
If it was the space saver spare which is much more common on the 2010-2013’s, then it’s a much bigger diameter than the 275/40R20’s. This is the space saver wheel/tire:
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631063 Thu Feb 23 2023 12:12pm
Jabba
Thanks, it was one the same as this, but with a tyre fitted Laughing
Post #631065 Thu Feb 23 2023 12:46pm
Jabba
Dave
Hi Dave, many thanks, just a little bit out of my price range as I want to hold back a couple of thousand just in case, but thank you
Post #631066 Thu Feb 23 2023 12:49pm
First one I'd be tempted to redrive it once the tyre is sorted. If everything is well then it's ok to consider it. Obviously, if the gearbox is still wrong then walk away.
The second one is total BS as others have said. 2012 SDV6 - it's missing a couple of cylinders
Post #631067 Thu Feb 23 2023 12:52pm
Jabba
Will do, the chap is getting the tyre sorted over the weekend, thanks RRSTDV8
Post #631068 Thu Feb 23 2023 12:57pm
karlos01
stick with the first one after the test drive
if gear box don't changfrim 1st to 3rd then walk away
second one is BS seller leave well alone
Post #631069 Thu Feb 23 2023 1:26pm
Jabba
The first chap has just called me saying he has had the tyre replaced and the gearbox is now working correctly. He knew I was concerned so thought he'd call before me going to see it again, nice of him.
Post #631076 Thu Feb 23 2023 5:08pm
My car came with this style and size spare from the factory, black as well.
Post #631091 Thu Feb 23 2023 7:53pm
Jabba
Hi, I've just had another look at the RRS book by James Taylor, he mentions that with the 2010 model, a new system called Adaptive Dynamics, apparently on the supercharged model it was called active roll control.
Looking into this, they used Bilsten DampTronic shock absorbers.
https://aerosus.co.uk/land-rover/range-rov...gLsrvD_BwE
Is this fitted to all models from 2010 ?
Could this be the special suspension that the dealer was on about ?
Many thanks
Craig
Post #631106 Fri Feb 24 2023 8:52am
