Home > Maintenance & Modifications > engine under tray removal
Kevin-t
Hi Folks.
Could I ask the wise, how may bolts hold the engine under tray? what size? does it just drop when bolts removed, or is it tucked in behind another tray. L494 4.4
Just had to have oil cooler gasket replaced after leak. mechanic got most if not all from top, however ran out of time to clean bottom.
Time is one thing I have plenty of!!!
Just thought I could/ maybe give it a go. Whistle Whistle Whistle
Advice welcomed..
Kevin-T Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #630745 Fri Feb 10 2023 12:22pm
If you've got time to spare, try the workshop manual:
https://www.mediafire.com/file/5hmml7nd29gabm0/RRSL494WSM2014.zip
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #630746 Fri Feb 10 2023 12:53pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Re: engine under tray removal
Kevin-t wrote:
Hi Folks.
Advice welcomed..
Kevin-T
Off the top of my head there are ten 15mm headed bolts with captive type washers, the back centre 2 are keyhole type , so undo and remove 8, then the back 2 can be loosened but left in the subframe threads and slide the tray forward to remove. Makes it easier when refitting as you offer the tray up and slide it along then can hinge the front upwards.
Take a look at the pic below, you'll see what I mean about the back 2.
https://store.landrover.com/parts/index/pa...and-rover/
Post #630747 Fri Feb 10 2023 1:11pm
Assuming it's metal like the L320 is, a trolley jack to support it would be a good thing to have too. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #630749 Fri Feb 10 2023 1:50pm
2 RRS
Heavy gauge aluminium on the 494 & 405, makes life a bit easier!
Post #630750 Fri Feb 10 2023 1:53pm
Kevin-t
Thanks Guys.
Thumbs Up Thumbs Up Thumbs Up
I can get use of a lift. How heavy approx? could one person manage it?
Whistle Whistle Whistle Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #630751 Fri Feb 10 2023 1:56pm
2 RRS
You'll manage it in one hand, nothing like the heavy trays on the L320. There's a sound deadening pad on the back of it, so will likely be soaked in oil if you had a leak, so maybe have some brake cleaner or similar available to clean it off.
Post #630752 Fri Feb 10 2023 1:59pm
Kevin-t
Great........ Thumbs Up Thumbs Up Thumbs Up
Thanks Once again. Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #630753 Fri Feb 10 2023 2:10pm
