Home > Maintenance & Modifications > engine under tray removal |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
If you've got time to spare, try the workshop manual:
Fri Feb 10 2023 12:53pm |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 142 |
Off the top of my head there are ten 15mm headed bolts with captive type washers, the back centre 2 are keyhole type , so undo and remove 8, then the back 2 can be loosened but left in the subframe threads and slide the tray forward to remove. Makes it easier when refitting as you offer the tray up and slide it along then can hinge the front upwards. Take a look at the pic below, you'll see what I mean about the back 2. https://store.landrover.com/parts/index/pa...and-rover/ |
Fri Feb 10 2023 1:11pm |
Assuming it's metal like the L320 is, a trolley jack to support it would be a good thing to have too. 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 10 2023 1:50pm |
Heavy gauge aluminium on the 494 & 405, makes life a bit easier! |
Fri Feb 10 2023 1:53pm |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 121 |
Thanks Guys.
Fri Feb 10 2023 1:56pm |
You'll manage it in one hand, nothing like the heavy trays on the L320. There's a sound deadening pad on the back of it, so will likely be soaked in oil if you had a leak, so maybe have some brake cleaner or similar available to clean it off. |
Fri Feb 10 2023 1:59pm |
Great........
Fri Feb 10 2023 2:10pm |
