![]() | Home > Maintenance & Modifications > Where are the + and - terminals on RRS 2010 battery |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I'm not familiar with the 2010 battery but if you are going to charge the battery whilst it's still connected, it's advised to connect the battery charger red lead to the positive terminal of the battery. The negative battery charger lead should go to a specific negative post, usually near the battery (might be in a little plastic box that when you open the lid, you will see the post to connect to.) 2016 RRS SVR Estoril Blue
Pretty clearly marked “modern” AGM battery for a 2005-2013 RRS:
L/R do advise removing the battery if charging to lessen the likelihood of shorting it out and damaging some of the ecu's etc.
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 119 ![]() ![]() ![]() |
Guys
Update. I’ve got me one of them Noco genius 10 chargers that also repair a battery as well if needed so along with that I’ve ordered some permanent fitted eyelet connector.
If I remember correctly if you disconnect the battery with the doors shut as soon as you disconnect it the doors will all lock, which is why I suggested leaving a door open, if you also fully close the bonnet after disconnection with the door shut you will have to get into the car using the key blade via the passenger door to release it, so at least leave the bonnet on the safety catch not fully closed.
Thanks as always Col |
In answer to the OP, the negative terminal is near the windscreen, the positive towards the FBH.
