Home > Maintenance & Modifications > Where are the + and - terminals on RRS 2010 battery
AIJ 615
Hi guys, brought a new battery charger last month and today had the battery low start engine message come up.
Question, modern batteries ain’t like the old style type and clearly marked with a the positive and negative (well I can see the positive but not the negative)
Anyone got a photo to edit to show me where to connect them to charge the Censored up ?
Post #630559 Fri Feb 03 2023 6:16pm
Scrumpy
I'm not familiar with the 2010 battery but if you are going to charge the battery whilst it's still connected, it's advised to connect the battery charger red lead to the positive terminal of the battery. The negative battery charger lead should go to a specific negative post, usually near the battery (might be in a little plastic box that when you open the lid, you will see the post to connect to.) 2016 RRS SVR Estoril Blue
Post #630561 Fri Feb 03 2023 6:53pm
NoExpert
Pretty clearly marked “modern” AGM battery for a 2005-2013 RRS:
Connect the positive to the positive and find a point on the body to attach the negative. This way the BMS (if fitted) reads the incoming charge and adjusts accordingly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #630565 Sat Feb 04 2023 7:41am
L/R do advise removing the battery if charging to lessen the likelihood of shorting it out and damaging some of the ecu's etc.
However if you remove the neg terminal first and isolate it, then the positive I see no need to remove the battery from the vehicle, it is advisable to switch the ignition etc, off and leave the vehicle for a few mins. before disconnecting the battery though, make sure the key is not in the car or just leave a door open. Reconnect pos. terminal first then neg. You will have to reset the date/time on the dash and one touch window operation as well after re-connecting battery, plus sunroof if you have one fitted.
col
Post #630566 Sat Feb 04 2023 7:44am
AIJ 615
Post #630568 Sat Feb 04 2023 8:21am
AIJ 615
Guys
Just a quick question then. If I remove the battery and trickle charge the battery over night then how does the locking go with the car. I’m guessing when I reconnect the charges battery the remote central locking is activated.
I’m just trying to figure out how it would work when I pull the front bonnet lever and then open up bonnet to remove battery surely the function to lock the doors would not be available.
Ideally I was gonna charge overnight so was wondering what the best way is ?
Al
Post #630585 Sat Feb 04 2023 8:20pm
AIJ 615
Update. I’ve got me one of them Noco genius 10 chargers that also repair a battery as well if needed so along with that I’ve ordered some permanent fitted eyelet connector.
Comes today so 👍
Anyone else used these chargers. The reviews are extremely good
Post #630600 Sun Feb 05 2023 8:58am
If I remember correctly if you disconnect the battery with the doors shut as soon as you disconnect it the doors will all lock, which is why I suggested leaving a door open, if you also fully close the bonnet after disconnection with the door shut you will have to get into the car using the key blade via the passenger door to release it, so at least leave the bonnet on the safety catch not fully closed.
That charger looks like a very similar type item to the ctek charger a lot of members use.
Post #630602 Sun Feb 05 2023 9:54am
AIJ 615
Thanks as always Col
Post #630603 Sun Feb 05 2023 9:56am
In answer to the OP, the negative terminal is near the windscreen, the positive towards the FBH.
Been that way from the start of the L320. 2012 SDV6 - it's missing a couple of cylinders
Post #630607 Sun Feb 05 2023 11:39pm
