Home > Maintenance & Modifications > Rear Right Height Sensor - C1A06-1C
jp1
Hi Guys
I have replaced the rear right sensor and continue to get this error. For the moment i'm assuming the new sensor is good
It also seems to correlate with the live values that there is a 5V supply but nothing being received.
I checked the wiring at the connector and it looked good, but will obviously have a closer look.
Is there any other tips anyone can recommend or a wiring diagram i can be pointed at ?
Many Thanks
Post #630528 Thu Feb 02 2023 6:41pm
jp1
Not sure how to post the pics but i added the IID screenshots to the gallery
Post #630529 Thu Feb 02 2023 6:41pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
Assuming the new sensor is okay you will have to look closer at the plug or check the wiring. have you put the multi meter on the connectors have you done continuity test ?
Post #630533 Thu Feb 02 2023 7:17pm
jp1
Thanks for reply
I'm assuming there is 5V, GND and Signal, will hunt down wiring diagram to confirm
I'll double check the wiring and also do a continuity check to GND and try and find the +ve 5V. To do continuity for signal, where does the signal go ? is there another plug somewhere or does loom goto direct to ECU ?
To check the new sensor I suppose I can supply 5V and measure the signal for output directly but for now, I'm assuming sensor is good (its brand new)
Thanks
Post #630536 Thu Feb 02 2023 7:27pm
jp1
It turns out it was a wiring issue. The yellow wire (+5v) was broken about 1" from the main harness, which meant it was a right pig to splice a new piece of wire on but finally managed to do it.
Ironically, the new LR020161 height sensor didnt work(!) so i put the old one back and its working fine. Not sure if its an incompatibility issue or just a faulty new part (my car is a 2006 2.7)
Post #630556 Fri Feb 03 2023 2:35pm
