![]() | Home > General > Possibly the best thing Range Rover ever has done |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
You cannot do what you suggest on the 2010 or earlier diesel models as there are two sump plugs and draining by the method you suggest would not drain the turbo return line sump. Also it is a good change to see if there are any leaks present when carrying out an oil change.
I think the double sump was only a thing on the TDV8 due to the turbos being placed lower in the engine bay than would be ideal. The oil return system was devised in order to ensure they drained when running at off road angles. 2012 SDV6 - it's missing a couple of cylinders
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Iv been using 1 of those for years, still drop the sump plug every now and again just to make sure there is nothing nasty hiding in there. |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 ![]() ![]() |
Performing all oil services to kick off the new year. Much more fun to remain standing.
SAK335 Member Since: 02 Apr 2022 Location: Henley-on-Thames Posts: 22 ![]() ![]() |
I bought an electric one at Lidl for £13. It's almost too easy. |
Mike H Member Since: 11 Mar 2022 Location: Nottingham Posts: 7 ![]() ![]() ![]() |
Just changed my oil and filter today. So simple and no mess. |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
I have a 6L one and when I tried it on the RRS I found the suction tube didn’t reach the bottom of the sump so I could only get about 4 and a bit litres out.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Buy a longer tube ? |
