Home > General > Possibly the best thing Range Rover ever has done |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 402 |
You cannot do what you suggest on the 2010 or earlier diesel models as there are two sump plugs and draining by the method you suggest would not drain the turbo return line sump. Also it is a good change to see if there are any leaks present when carrying out an oil change.
Sun Jan 01 2023 7:35am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I think the double sump was only a thing on the TDV8 due to the turbos being placed lower in the engine bay than would be ideal. The oil return system was devised in order to ensure they drained when running at off road angles. 2012 SDV6 - it's missing a couple of cylinders
Sun Jan 01 2023 6:28pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 344 |
Iv been using 1 of those for years, still drop the sump plug every now and again just to make sure there is nothing nasty hiding in there. |
Sun Jan 01 2023 7:42pm |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 |
Performing all oil services to kick off the new year. Much more fun to remain standing.
Mon Jan 02 2023 10:05pm |
SAK335 Member Since: 02 Apr 2022 Location: Henley-on-Thames Posts: 22 |
I bought an electric one at Lidl for £13. It's almost too easy. |
Sat Jan 14 2023 10:29am |
Mike H Member Since: 11 Mar 2022 Location: Nottingham Posts: 7 |
Just changed my oil and filter today. So simple and no mess. |
Sun Jan 15 2023 1:51pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
I have a 6L one and when I tried it on the RRS I found the suction tube didn’t reach the bottom of the sump so I could only get about 4 and a bit litres out.
Thu Jan 19 2023 4:33pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1829 |
Buy a longer tube ? 2023 P440e SE Dynamic on order -cancelled
Thu Jan 19 2023 5:23pm |
