![]() | Home > Maintenance & Modifications > new RRS 2005 hse owner, preventative maintenance. |
nation1 Member Since: 09 Jan 2023 Location: Belper Posts: 8 ![]() ![]() ![]() |
Good evening everyone, Bought a RRS hse 2005 last week 123,000, I am the 3rd owner of the car, previous owner was a consultant and owned the car from 2007-2023. Has full service history with no expense spared, all receipts of repairs & services to back up. The car had a basic service oil/filter before leaving the car dealer with a full 12 months mot and 3 months warranty. The car is straight and not modified in any way. Me & my wife were looking around for a while before purchasing and we think we have found a good solid car.
2.7 TDV6?
HI, no sunroof, ACE ? active cornering enhancement ? how do I know if I have this ? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
The oil pump became a problem around 2007 (IIRC) as the design was changed to a weaker one. It was reverted to a stronger design when the failures started, so your 2005 should be ok on that front. The weak ones usually fail not long after the belts are done.
Brake fluid and flexible brake lines should have been done too but probably only ever get done "if required". Coolant should be replaced every 10 years too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
ACE has a reservoir in the engine bay. Lift the bonnet and look for a yellow capped reservoir. If you have only one and it's on the right of the engine as you're looking at it, then you don't have ACE. If you have a second reservoir and it's on the left of the engine (by the air filter box) then you have ACE. ![]() 2008 TDV8 - it was a labour of love and is much missed |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Replace with the original Land Rover item, if not FoMoCo or Citroen. Never with 3rd party or so-called claimed OEM stuff. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hi and welcome. Good to see another 2005 owner here.
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 ![]() ![]() ![]() |
That looks like an extract from online service manual, please could you point me at it? Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
Superb, thank you! Gone: 10MY L320 RR Sport HSE, Ipanema Sand
I’d still go for the oil pump, it’s had 18 years of service. I changed mine with only 11 years of service and noticed a difference. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Yes get that oil pump replaced it's defo on borrowed time
At least it's not an engine out, sump off job like it is with the TDV8's oil pump. |
