![]() | Home > Technical > hdc fault |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Is that code not showing a dodgy brake light switch, which is not uncommon and can cause the HDC to throw a wobbly I believe. Could do with the other two digits that go with that code as there are several that start P0504, although they all suggest a switch failure as one of several possible causes.
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
thanks col
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
I get this once every 10-18 months. Brake switch is the solution. |
codes this morning
hi folks got a rear wheel speed sensor subfault (ABS sensor) I've cleaned the connections and checked for splits in wires but when I removed the sensor from housing I've noticed it has a Grove cut in it
owned p38 before sport so know a bit about these so question is does the rear hub cut the Grove in to create the air gap needed for the sensor to work or is there something wrong for the hub to be doing this to the sensor |
just a update on this
