![]() | Home > Technical > SVR 2016 engine & warning triangle |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
You will need to read the fault codes to find out what's going on. --
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Can't really comment on the L494, but on my old L320 5.0L . Switch ignition on, once it's gone through it's checks the only lights left on are Yellow Warning Triangle, Battery Light and Engine Light, press brake pedal to start and Warning Triangle goes out, start engine and Battery Light goes out then the Engine Light a nano second later, never been any different. Does that Airbag warning light extinguish ? as that may be the cause of the Warning Triangle staying illuminated, but as suggested you do need the codes read.
