Home > General > fuel burning heater
loonyball
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
fuel burning heater
hello everyone, a strange thing happening with the FBH on my 2012my RRS, when i set the timer for the FBH on the infotainment screen the heater doesn't work, i've tried the manual 'instant heat' button and the heater starts up and runs for maybe 60-90 seconds then shuts down, yet when i start the engine the FBH runs fine and stays on for quite some time, i have checked for any faults or codes with my iid scan tool but no faults or codes present, fuel level always above half full, battery in tip top condition, any thoughts ???
Post #629052 Mon Dec 12 2022 11:38pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
So the heater starts okay but doesnt stop on long but only happen sometimes with no soft code stored? just sounds like it had a
splutter with fuel very surprised it didn't show it self on IID.
Post #629078 Tue Dec 13 2022 10:18pm
You say it runs for 60-90 seconds, but is this just it's start cycle and then shuts down because it hasn't fired up or does it actually fire and not run. Are you getting any excess smoke or fuel vapour from the exhaust at all.
Post #629079 Tue Dec 13 2022 10:38pm
loonyball
Hi lads, thanks for the replies, yes the burner does fire up, a small waft of smoke and the usual smell of fumes, runs for a minute, maybe two and then cycled down and shuts off, start the engine and it runs normally, as i said, no codes on iid 🤷‍♂️
Post #629080 Wed Dec 14 2022 12:25am
Have you used the IID tool to bleed/prime the system and check operation to see if that helps at all.
Post #629081 Wed Dec 14 2022 12:48am
NoExpert
My FBH only runs for about two minutes when I hit manual heat as well, very annoying. My timed heat works like clockwork though, in fact it’s running right now. Did you activate the system yourself or this is a factory option? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #629082 Wed Dec 14 2022 6:31am
loonyball
it wasn't activated on my car but i did it myself with the iid tool, works fine when engine running but not when i select 'manual heat' i haven't tried the timer so i might just try that and see what happens....
Post #629087 Wed Dec 14 2022 10:40am
NoExpert
I’m in the same boat. Check the timed heat/vent and see if it works. I’m still trying to find why the manual heat/vent option doesn’t work as it should on mine. Probably some odd setting or module that needs to be activated. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #629092 Wed Dec 14 2022 2:38pm
loonyball
Set the seven day timer last night and this morning got in to a frost free toasty warm range rover, happy days !
Post #629121 Thu Dec 15 2022 12:57pm
