![]() | Home > General > fuel burning heater |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
So the heater starts okay but doesnt stop on long but only happen sometimes with no soft code stored? just sounds like it had a
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
You say it runs for 60-90 seconds, but is this just it's start cycle and then shuts down because it hasn't fired up or does it actually fire and not run. Are you getting any excess smoke or fuel vapour from the exhaust at all.
loonyball Member Since: 29 May 2019 Location: ballymena Posts: 30 ![]() ![]() ![]() |
Hi lads, thanks for the replies, yes the burner does fire up, a small waft of smoke and the usual smell of fumes, runs for a minute, maybe two and then cycled down and shuts off, start the engine and it runs normally, as i said, no codes on iid 🤷♂️ |
Have you used the IID tool to bleed/prime the system and check operation to see if that helps at all.
My FBH only runs for about two minutes when I hit manual heat as well, very annoying. My timed heat works like clockwork though, in fact it’s running right now. Did you activate the system yourself or this is a factory option? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
it wasn't activated on my car but i did it myself with the iid tool, works fine when engine running but not when i select 'manual heat' i haven't tried the timer so i might just try that and see what happens.... |
I’m in the same boat. Check the timed heat/vent and see if it works. I’m still trying to find why the manual heat/vent option doesn’t work as it should on mine. Probably some odd setting or module that needs to be activated. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Set the seven day timer last night and this morning got in to a frost free toasty warm range rover, happy days ! |
